2003 Chrysler Town and Country won't start
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOE NEIL
the battery died , I put charger on this a.m., car will turn over but not start, the gauges are not lighting up or activating.
Jan 5, 2008 at 6:46 AM
  • 31,937 POSTS
Hi there,
If battery is fully charged, check for spark first, if you have spark make sure the plugs are not fouled with fuel, Is the fuel pump working? check all relevant fuses first, Engine, fuel pump, ECU. If it was running well before you got a flat battery i may be something minor, check these first and re post if you still need assistance.
Mark (mhpautos)
Aug 30, 2020 at 4:53 AM
