2003 Chrysler Town and Country water leaks into passenger s
2003 CHRYSLER TOWN AND COUNTRY
100,000 MILES • 6 CYL • FWD • AUTOMATIC
LIGHTWAY
Water from the air conditioner drain is leaking back into the front passenger side of van onto the floor mat. We checked drain and not obstructed. We replaced filter and yet still leaking in. What is causing it?
Jul 15, 2010 at 12:35 AM
  • 110,244 POSTS
If the drain isn't plugged, then check the gasket between the plastic box where the heater core and AC components are located. Remove the glove box and covers to gain access to determine where the leak is coming from.
Jul 16, 2010 at 3:24 PM
