My battery is dead about every 4th day?
137,000 MILES • 6 CYL • FWD • AUTOMATIC
JMPUGMIRE
My battery is dead about every 4th day. I had it tested and it is fine. I was told to replace my alternator and did that and I am still having the same problem.
I have been told it could be my voltage regulator but I cannot find one for this vehicle.
I have also been told to test the "cut-out" and have it replaced but I do not know what that is.
Any suggestions.
Sep 25, 2008 at 7:02 AM
  • 55,512 POSTS
I have not heard of the cutout wire and the voltage regulator is built into the alternator; do you have CD player because if a CD gets stuck it will drain the battery down. Here is a guide to help you check the other simple things that will cause the battery to drain down:
https://www.2carpros.com/articles/car-battery-dead-overnight
Jul 12, 2022 at 10:01 AM
