2003 Chrysler Town and Country stalls out
DOLL9GIRL
  • 2003 CHRYSLER TOWN AND COUNTRY
  • 6 CYL
  • 140,000 MILES
Why does my car stall out and want crank asnd then sometimes it want do nothing not turn over but will click int he dash like its comeing but want start and I can keep turning it on and off and then it will crank
Saturday, December 12th, 2009 AT 12:05 PM
CARADIODOC
  • 34,088 POSTS
Pleased proofread your post. As near as I can make out, if you turn the ignition switch to the "crank" position enough times, it will eventually start. Is that right? If you hear one kind of loud clunk from the starter but it doesn't spin the engine, suspect worn contacts in the starter solenoid. They can be replaced for 20 bucks but most people just replace the entire starter. This is a real common problem with an easy fix.
Caradiodoc
Wednesday, December 16th, 2009 AT 7:33 AM
