2003 Chrysler Town and Country Speedometer and gas guage no
2003 CHRYSLER TOWN AND COUNTRY
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
SIGNSNY
I had my tranmission rebuilt.After that check engine light came on ,speed o meter not working and gas guage is giving me wrong amount of gas.I filled it up and after driving 20 miles the neeedle goes down to 25% but the gas is in the tank.
Please advise i really need some of your expertise.
Mar 7, 2009 at 1:31 PM
  • 110,244 POSTS
Two things need checked. First, disconnect the battery for about 10 minutes to see if that will reset the BCM. If that does nothing, have the body control module (BCM) tested. If it is good, the float in the fuel tank is most likely bad. It is part of the fuel pump, so it's not a cheap part.
Mar 20, 2009 at 3:40 AM
