2003 Chrysler Town and Country remove drivers inside door p
89,000 MILES • 6 CYL • FWD • AUTOMATIC
PIEHL
remove driver's insidedoor panel to replace windowregulator
May 20, 2009 at 11:50 AM
  • 110,248 POSTS
There should be a few screws along the bottom of of the panel. You will need to remove the arm rest, unscrew the plate behind the handle and then remove the clips between the panel and the door itself.
May 24, 2009 at 12:21 PM
