2003 Chrysler Town and Country Radiator
2003 CHRYSLER TOWN AND COUNTRY
TOMSILTZ
Engine Cooling problem
2003 Chrysler Town and Country 6 cyl Automatic 145000 miles
I've been filing up my radiator with a gal of antifreeze on a weekly-biweekly basis, I checked for leaks, but their is None. What else can I check or what would make this happen?
Tom
Mar 4, 2010 at 10:53 PM
CARADIODOC
  • 34,381 POSTS
Head gasket. Check for white smoke out of the tail pipe.
Mar 8, 2010 at 6:23 PM
TOMSILTZ
I checked the oil to see if the antifreeze is mixing with the oil. Nothing. No white smoke.
Mar 8, 2010 at 11:09 PM
CARADIODOC
  • 34,381 POSTS
Two possible plans of attack. Use a pressure tester to pressurize the system and watch for a leak, or add a small bottle of dye, drive for a few miles, then shine a black light around. The dark purple dye will appear bright yellow under a black light.
caradiodoc
Mar 9, 2010 at 2:51 AM
