2003 Chrysler Town and Country Heater Fan won't shut off/do
2003 CHRYSLER TOWN AND COUNTRY
127,000 MILES • 6 CYL • FWD • AUTOMATIC
SHIRLEY I.
I have an automatic climate control heater/air that I can shut off the automatic part and control myself. I'm having issues with my heater fan. The fan only blows at high speed it won't turn down to low or med. This happens even when I turn the heater/air conditioner off. When I turn system off, the vents shut off where nothing comes out of the vents but then it sounds like it is pushing the air out by the front passenger floorboard area or somewhere under the dash. The heat seems to operate okay as far as temperture it heats up and cools down, vehicle temp runs pretty much in middle of temp gauge where it always does.
Jan 18, 2010 at 4:28 AM
  • 110,244 POSTS
Try replacing the blower motor resister. It's a cheap part. Let me know if that takes care of the problem.
Jan 18, 2010 at 2:05 PM
SHIRLEY I.
Thank you for your help. This did solve the issue.
Shirley
Jan 25, 2010 at 12:19 AM
