2003 Chrysler Town and Country front end bumping noise
118,500 MILES • 6 CYL • 2WD • AUTOMATIC
JOETHEELDER
When going over small bumps in the road, the front makes a noise like something is loose. The mechanics I've taken it to have no clue. What could it be?
Sep 29, 2010 at 9:38 AM
F4I_GUY
  • 3,302 POSTS
Thanks for your donation!
This shouldn't be a tough one to figure out. Sway bar bushings and endlinks are common on your vehicle. Have a good front-end mechanic try and diagnose the problem. Some other possible causes could be, worn control arm bushings, broken strut or a loose ball-joint. But typically it's either the sway bar links and/or bushings on the vehicle causing the problems.
Sep 29, 2010 at 10:28 AM
