Engine Performance problem
2003 Chrysler Town and Country 6 cyl Two Wheel Drive Automatic 80K miles
I was browsing your forum and noticed a vehicle with a similar problem - the suggestions were fuel pump. Are their any idle senors that could be the problem - don't want to purchase new pump. Problem started after what I thought was a bad tank of gas. Have run two fuel injector cleaners through and many tanks of gas, same problem only when cold at start up not wanting to idle - will choke out if you don't give it a lot of gas.
Oct 1, 2008 at 12:41 PM
