2003 Chrysler Town and Country Engine Stalls, but only cold
90,000 MILES • 6 CYL • AWD • AUTOMATIC
JBRYAN107
My van recently began stalling. Mechanic found no codes. Fuel pressure was lower than design pressure but not drastically low. I think it was about 80% of normal. So he recommended replacing the pump to see if that would take care of it, but he had his doubts that it was the real problem. Since it is an expensive repair, I'd rather not do it if it's not the problem.
What else could it be? One thing that makes me doubt the pump is the problem is that the car idles fine and also stops stalling once the car has run for a few minutes. I can start the car and it will idle fine as long as I want. Only when I put it in gear AND give it that first bit of throttle will it stall. From idle in park, if I put it in gear but keep the brake on and give it no throttle it doesn't stall. Once I give it some throttle it stalls, but only if low throttle. If I put it in gear and immediately give it a decent amount of throttle it can go right through the hesitation which is barely perceptible in that case. And after only a couple minutes of running it will no longer stall regardless of throttle level. So even at very low throttle it will not stall once it has run for a few minutes.
Finally, does the 80% output of the fuel pump necessarily mean that the pump is dying, or is it possible the pump will operate fine at 80% for a long time.
Sep 11, 2008 at 3:40 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Any time fuel pump pressure is below minmum the problem needs to be corrected. Your vehicle needs 53-63 psi. Fuel pressure is necessay to supply proper fuel delivery across various engine conditions. When cold engine needs richer mix so when you crack throttle it may stall. When you press further you get tip in hesitation. So your problem maybe fuel pump. Has delivery rate been checked? 7 seconds deliver .5 pt.
Other causes TPS
Throttle body needs good cleaning, Chry has TSB 14-002-07 out on your van concerning throttle service. Also dirty injectors and cxarbon build up on valves can attribue to this condition. If these services have not been done in 90K I would start there.
Hope this helps
Thanks for your donation
Sep 11, 2008 at 4:46 AM
ALABAMACATFISH
I have the same year and model of minivan with the exact same problem. Let me know if it is a problem with the fuel pump. I was hoping it would be something a simple as an idle sensor.
Oct 1, 2008 at 12:43 PM
