2003 Chrysler Town and Country engine light on with codes
ORSKOV05
  • 2003 CHRYSLER TOWN AND COUNTRY
  • 6 CYL
  • 121,034 MILES
Just had my crhysler into dealer was running way to rich and throwing two engine codes p0148 p0118 and batt light was on had to tow it being as it would hardly run enough to drive they said it was alternator. They wanted 600 for it so I did myself funny part was I went to pick it up and it seemed like it was running fine. But then I replaced alternator and now getting more engine codes codes im now getting p0108 and p0203 would like to figure out on my own without paying dealer again. Its running but it will like stuble when driving it will do the same when your steady on throttle. And then back off it will stuble.
Saturday, July 3rd, 2010 AT 6:21 PM
  • 109,885 POSTS
P0203 Injector Circuit Malfunction - Cylinder 3
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
Start by having the map sensor checked. It could be causing the problem with the injector. However, you may want to check the wiring to the injector and make sure it is getting power. You need a noid light. It plugs into the wiring to the injector and should pulse when the injector is firing. As far as the noid light, most parts stores will lend or rent them to you. They are not expensive.
Let me know what you find
Thursday, July 8th, 2010 AT 9:00 PM
