2003 Chrysler Town and Country Blowers only work on high
132,000 MILES • 6 CYL • 2WD • AUTOMATIC
WDKOSECK
When I turn the blowers on in my van the only setting that works is the high setting. All other settings no longer work.
This just happened a couple of days ago and I am wondering what can be wrong and if it willbe expensive to get fixed.
Jan 5, 2010 at 3:05 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check blower motor relay. if OK test heater control switches. if switches are good too then suspect faulty blower motor resistor.
Jan 8, 2010 at 12:47 PM
WDKOSECK
Thanks for the information.
I will try replacing the Blower Motor Relay and see what happens.
Jan 8, 2010 at 1:04 PM
