2002 Chrysler Town and Country Transmission will not shift
68,000 MILES • 6 CYL • FWD • AUTOMATIC
RABLMA
Van drove/shifted great one day. The next day transmission would not shift. Have replaced input sensor, output sensor, changed transmission fluid and filter, and replaced an electronic transmission shift module on front of transmission. Transmission still will not shift. Is there a transmission relay on this van. If so, where is it located as we cannot locate it. Any other suggestions to try?
May 14, 2008 at 1:02 PM
MASTERTECHTIM
  • 4,750 POSTS
if the check engine light is on you need to scan the computer for codes. auto zone does it for free, then get back to us. possible bad ignition switch not sending power to trqansmission.
May 14, 2008 at 1:09 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:ec6a5fad29="rablma"]Transmission problem
2002 Chrysler Town and Country 6 cyl Front Wheel Drive Automatic 68000 miles
Van drove/shifted great one day. The next day transmission would not shift. Have replaced input sensor, output sensor, changed transmission fluid and filter, and replaced an electronic transmission shift module on front of transmission. Transmission still will not shift. Is there a transmission relay on this van. If so, where is it located as we cannot locate it. Any other suggestions to try?[/quote:ec6a5fad29]
There are a few other possibilities....
The Tranny Computer, the tranny itself or possibly the Torque Converter.
May 24, 2008 at 3:53 PM
