2002 Chrysler Town and Country Rear brake pad replacement
2002 CHRYSLER TOWN AND COUNTRY
61,060 MILES • 6 CYL • FWD • AUTOMATIC
WHOPIECAT
On the rear of the front wheel drive 2002 Town and Country van the disc brake caliper is located on the top of the rotor and centered. There does not seem to be a way to separate the caliper from the rotor. There are no caliper mount bolts, there are only hub mount bolts. How do I remove the caliper to replace the pads? Thanks
Apr 11, 2009 at 6:30 PM
CARADIODOC
  • 34,321 POSTS
The two caliper mounting bolts are inside rubber sleeves on the back of the caliper. As I recall, they are 10mm Allen head bolts. Replace them if they have rust pits. If the chrome plating is in good shape, lube them with a high temperature brake grease. The same grease used on the pads is fine.
caradiodoc
Mar 15, 2021 at 12:34 PM
WHOPIECAT
[quote:2caa068c01="caradiodoc"]The two caliper mounting bolts are inside rubber sleeves on the back of the caliper. As I recall, they are 10mm Allen head bolts. Replace them if they have rust pits. If the chrome plating is in good shape, lube them with a high temperature brake grease. The same grease used on the pads is fine.
caradiodoc[/quote:2caa068c01]
Thanks for getting back so quick.
