Every so often when the van is started and the engine is running, we loose power to power windows, hvac blower, wipers, and radio. When we turn the key just to the on position, but the engine is not running, all functions return. When this occurs, I have giggled wires randomly under the dash and can often get the power to return with the engine running. It is then O.K. for 2-3 months, then the problem returns. Local repair shop diagnosed a bad starter switch. The switch was replaced, but the problem has returned. Any help would be appreciated.
Dec 3, 2009 at 1:04 PM
