2002 Chrysler Town and Country Noises
2002 CHRYSLER TOWN AND COUNTRY
MALISA.CHATMAN
Noises problem
2002 Chrysler Town and Country Automatic 114000 miles
When I hit a bump in the road or go over a speed bump, I ha this rattling noise like something is loose. What could this be?
Feb 1, 2009 at 8:15 PM
PAAKRAAT
This may seem silly, but the same thing happened to my T&C. It drove me nuts until someone suggested I check the spare tire. Sure enough, it was loose. Have you checked yours?
Feb 1, 2009 at 11:29 PM
REBELLONG
I have a 2001 T & C that was making a noise that sounded like something was loose in the front end. Mine turned out to be two worn out bushings on the control arm that mounted it to the lower portion of the firewall behind the engine. You may want to check those. On mine you could tell where the control arm had play in it where it looked like it was sliding back & forth and had rub marks on either side of the bushings. Hope this helps.
Mar 6, 2009 at 7:51 AM
