2002 Chrysler Town and Country ignition
64,000 MILES • 6 CYL • 2WD • AUTOMATIC
BLAMOUNTAIN
My key suddenly does not work How do I change the ignition cylinder
Sep 7, 2008 at 5:31 AM
  • 110,244 POSTS
Hi: Have you tried a different key? I've seen problems where the key has actually worn to a point that it no longer works.
If that isn't the case, replacing the ignition switch on avehicle with an air bag needs to be done by a professional who knows what to do. If you're not sure what to do, you could deploy the air bag when removing the steering wheel.
If you have any other questions, let me know.
Oct 6, 2008 at 8:23 AM
