2002 Chrysler Town and Country Heat and A/C fan motor stuck
2002 CHRYSLER TOWN AND COUNTRY
109,000 MILES • 6 CYL • FWD • AUTOMATIC
CARRPB
I found a similar post for a 2003 but no resolution. The fan motor operates on high, cannot adjust speed but can change temp and air flow direction. This happens with the HVAC controls turned off. When the controls are turned on, everything operates the same as above but it sounds like it goes into re-circulate mode.
Mar 21, 2009 at 9:08 AM
CARADIODOC
  • 34,338 POSTS
You'll need to clarify the symptoms.
"fan motor operates on high, cannot adjust speed but can change temp and air flow direction. This happens with the HVAC controls turned off."
Nothing should be working if the controls are turned off. Do you mean the air conditioning is turned off but the heater is turned on?
'96 and '97 minivans needed to have a relearn procedure done anytime the battery was disconnected or run dead. Half of the procedure can be very frustrating and time consuming to pass. By 2000, the procedure was either simplified or it wasn't required, I can't remember; and, I don't think that applies to your 2003. Nevertheless, I would check the service manual, (sorry, I don't have one), for a calibration procedure. If there is none, I'd suspect the HVAC computer.
This is the main reason I'm still driving my '88 Grand Caravan; no over-complicated unreliable computers, and my heater works just fine. "Thanks, car manufacturers"!
caradiodoc
Mar 22, 2009 at 10:46 AM
SNOWFLAKE2009
i have a 2001 t&c, same problem, several people have told me the same thing, the heater fan or blower resister is bad. mine is not fixed yet, but will post if it is the problem.
Mar 30, 2009 at 11:53 AM
SNOWFLAKE2009
replaced heater fan resistor behind the glove boxand it is working like new. take the vin number to a chrysler dealer, part stores do not have the for automatic temp control. around $80.00. easy to change. good luck.
Apr 14, 2009 at 2:18 PM
