2002 Chrysler Town and Country hard shift
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
PAULANDLUCIA
2002 Town & Country Chrysler w/ a 3.3 liter engine & 4-speed trans; I'm having a hard shift on deceleration between 3rd & 2nd gear. I have replaced the front transmission mounts and both axles. Any advice?
Jan 27, 2009 at 3:27 AM
  • 110,248 POSTS
Hi:
did the problem just start since the parts were replaced?
Also, there are electronic shift solenoids in the trans that may be going bad or have a wiring problem. You may need to have them checked. If they are determined bad, they are not hard to replace. If you have removed a trans filter, you would be able to replace them.
Let me know what you find.
Feb 3, 2009 at 10:51 AM
