2002 Chrysler Town and Country Erattic speedometer and down
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
DONNAJEAN
When I am driving my car the speedometer will all of a sudden bounce up and down erattically and it will downshift from overdrive. I have not seen a mechanic yet but am planning on it soon. Should i take it to a transmission guy or a regular mechanic? It doesn't happen all the time but often enough. The transmisiion will jerk suddenly too. Any ideas? Thank you!!
May 12, 2008 at 12:32 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:ae16c8bbb6="donnajean"]Transmission problem
2002 Chrysler Town and Country 6 cyl Two Wheel Drive Automatic 105000 miles
When I am driving my car the speedometer will all of a sudden bounce up and down erattically and it will downshift from overdrive. I have not seen a mechanic yet but am planning on it soon. Should i take it to a transmission guy or a regular mechanic? It doesn't happen all the time but often enough. The transmisiion will jerk suddenly too. Any ideas? Thank you!![/quote:ae16c8bbb6]
Is the check engine light on?
When was last tranny service?
Could possibly be the Input and/or Output Speed Sensors.
There is also a shift selenoid pack mounted on the front of the tranny.
I would reccomend taking it to a transmission shop.
May 24, 2008 at 4:08 PM
DONNAJEAN
I did take it to my regular mechanic and he suggested a transmission guy. I had a couple of friends that knew about the sensors so I bought a repair manual and we were going to fix it. Well I was trying to locate the sensors and found them. I noticed that the output sensor seemed a bit loose, so I disconnected the electrical part and reconnected it. It seems to be fine now. It hasn't acted funny since..haha so Hopefully I fixed it but I do plan on taking it to a transmission guy soon just to have it checked out!! Thank you for your help!!
May 25, 2008 at 2:56 AM
