2002 Chrysler Town and Country electrical
102,000 MILES • 6 CYL • FWD • AUTOMATIC
MARKGALLAHER449
wipers radio p windows intermittantly will not work when vehicle is started but will work when switch is in on position
Dec 27, 2008 at 5:35 AM
  • 110,244 POSTS
Hi:
It could be a ground problem or a bad Body Control Module (BCM). try disconnecting the battery for 5+ minutes to see if it will reset. If it doesn't, you will need to have a mechanic with the proper test equipment check it.
Let me know what you find.
Dec 27, 2008 at 3:50 PM
