2002 Chrysler Town and Country coolant leak
DADOTWINS
Engine Cooling problem
2002 Chrysler Town and Country 6 cyl Front Wheel Drive
recently i've noticed antifreeze on the drive way. i refilled the radiator and looked for leaks - nothing ! today it was low again so being in a hurry i had the engine running as i replaced the antifreeze looking under again i noticed steady stream coming from the radiator closer to the passenger side. Any ideas? Thermostat? Water pump? Of just a plain link? Any help will be appreciated.
Nov 25, 2009 at 11:51 AM
BMRFIXIT
  • 19,053 POSTS
Pressure check the coolant system
if have rear heater check its tubes under the passenger side
Nov 25, 2009 at 12:00 PM
