Vehicle is equipped with Automatic Tempurature Control (ATC) (climate control)
Blower only runs at high speed and can not be adjusted. If I shut off the power to the ATC system, what sounds like the recirculation fan starts and can not be adjusted - so the blower is running regardless. I have tested the blower relay and it appears to be fine. Could this be the Blower Motor Resistor? Apparently the ATC systems use what is called a Blower Power Module, rather than just a blower motor resistor. Is it likely this Power module is the problem? Please advise what may be causing this problem.
Thanks!
Thanks!
Jan 6, 2009 at 4:27 AM
