2002 Chrysler Sebring Partially inop a/c-heater co
51,000 MILES • 4 CYL • FWD • AUTOMATIC
MOONLIGHTER86
I have a a/c-heater control switch that only operates in the highest (level 4) position. Levels 1 through 3 are conpletely inop in both a/c and heating operations. The fuse to the heater motor seems okay since it does operate on level 4. What would be you suggestive steps to tracking this problem down?
Thanks,
Joe Doyle
Sep 1, 2008 at 3:18 AM
  • 110,244 POSTS
Hi Joe:
The first thing I would have checked would be the fan switch itself. If it's good, then it is most likely the blower motor resistor.
Oct 6, 2008 at 8:50 AM
