2001 Chrysler Town and Country Turn Signal intermitent fail
90,000 MILES • 6 CYL • FWD • AUTOMATIC
RONW5566
Sometimes when using the signal it fails to function. Other times, when applied for a Right turn the Left signal will flash. Other times it works fine.?..
Repair suggestions?
Nov 4, 2009 at 10:30 AM
CH112063
  • 1,320 POSTS
There were problems with these type of multi-function turn signal switches. That is probably causing this. Try that if it is not something like a socket or wiring problem. ok It is not too old.
Nov 5, 2009 at 12:23 PM
