start up noise when engine i
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
JESSBILL
Every morning my van will make the following noise:
rruupp! for about ten seconds and then goes away. Sometimes, if it sets for a long period of time during the day the name noise will come back when started. I checked all fluids and they are ok. The power sterring is fine. Why does this noise happen at a cold start up?
Bill
Dec 17, 2009 at 11:19 PM
RACEFAN966
  • 5,029 POSTS
I don't know why without actually hearing it. But there is a service bulletin on the power steering pump moan/groan noise at start up when cold. They say it is from using the wrong fluid. If that is case then buy a cheap turkey baster and remove the old fluid from the pump and replace it with ATF+4 and see if that fixes it.
Dec 18, 2009 at 2:12 AM
TSEWNOJ
[quote="jessbill"]Noises problem
2001 Chrysler Town and Country 6 cyl Two Wheel Drive Automatic 115000 miles
rrrrrrrrruuuuuuuupppppp! for about ten seconds and then goes away. Sometimes, if it sets for a long period of time during the day the name noise will come back when started. I checked all fluids and they are ok. The power sterring is fine. Why does this noise happen at a cold start up?
Bill - I know the noise your talking about. I have had my starter checked as well as the alternator by my local garage. So far nobody has figured out what the problem is. If you get any successful in please post your findings. Thanks.
Dec 27, 2009 at 5:22 AM
