2001 Chrysler Town and Country runs ruff
125,000 MILES • 6 CYL • AWD • AUTOMATIC
RACER
  • 8 POSTS
2001 town and country 3.8 AWD with 125000 miles just starded to run ruff half way through a full tank of gas, check engen light came on with po300,po303 &po306 I had replaced the plugs 2 mo earleyer so i checked the wires and they looked good and had low resetence so I checked the coil as #3 and#6 fire at the same time there was some carbon tracks so I replaced it and cleared the codes, after 2 days of driving it started to act up aging and the check eng. light came on with po300 and as the plug wires were under warenty i replaced them and clerd the code aging.it has run fine for a few days but it has started to run ruff at times and when i acclerate hard the check eng light will flash but there are no hard codes or pinding codes in the computer. any idaes?
Jan 19, 2008 at 1:08 PM
PHARMTECH
  • 5 POSTS
I am no professional, but I have had a similar problem before, the flashing engine light sorta gave it away... is the catalytic converter plugged??....just a thought
Jan 23, 2008 at 11:45 AM
RACER
  • 8 POSTS
one of the first things i checker its good thanks
Jan 24, 2008 at 8:52 AM
RACER
  • 8 POSTS
found the problem the wiring harness for the injectors got to close to the crosover pipe and melted
Jan 26, 2008 at 10:50 AM
