2001 Chrysler Town and Country p0256
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
CORVETTEL98
What are some things I could try, to resolve a engine
code p0256(injection pump metering control mal-function cam/rotor/injector) on a 01 Chrysler mini-van?
Thanks for your help!
Oct 13, 2010 at 2:59 PM
BLUELIGHTNIN6
  • 16,542 POSTS
P0256 - Injection Pump Fuel Metering Control B Malfunction (Cam/Rotor/Injector)
P0256 Description
The ECM detects a discrepancy between the Pulse-Width Modulation (PWM) supplied to the Electronic Fuel Control Actuator (FCA) and the PWM returned from the Electronic Fuel Control Actuator (FCA).Symptoms- Engine Light ON (or Service Engine Soon Warning Light)
Possible Causes
- Fuel Pump
- FCA Driver Open
- Return Circuit Open from FCA to ECM
- FCA Driver Circuit Shorted to External Voltage
- FCA Return Circuit Shorted to External V
Oct 13, 2010 at 3:47 PM
CORVETTEL98
Your answer really helps to give me a place to start.
Thanks so much! I'm glad I found your website.
Oct 14, 2010 at 1:12 AM
