2001 Chrysler Town and Country P0202 Injector Circuit
2001 CHRYSLER TOWN AND COUNTRY
106,000 MILES • 6 CYL • 2WD • AUTOMATIC
RICHARDJMACE
I replaced my ECM due to a P0601 code,
When I installed the new (rebuilt) ECM I now have a P0202. How would you recommend fixing?
Note:
I removed the #2 spark plug wire no change in engine.
I then removed the # 6 spark plug wire no change in engine nor any additional error code.
Mar 27, 2009 at 11:18 AM
P0202 - Cylinder 2 Injector Circuit Malfunction
What does that mean?P0202 means that the PCM detected a fault in the injector or the wiring to the injector. It monitors the injector and when the injector is activated, the PCM expects to see the voltage pulled "low" or close to zero. When the injector is switched off, the PCM expects to see a voltage that is close to battery voltage or "high". If it doesn't see the expected voltage the PCM will set this code. The PCM also monitors resitance in the circuit. If the resistance is excessively low or high it will set this code.
Potential SymptomsThe symptoms for this code will likely be a misfire and a rough running engine. Poor acceleration. The MIL will also be illuminated.
CausesThe causes of a P0202 engine light code could be any of the following:
Bad injector. This is usually the cause of this code but doesn't rule out the possibility of one of the other causes
Open in the wiring to the injector
Short in the wiring to the injector
Bad PCM
Possible Solutions First, using a DVOM check the resistance of the injector. If it isn't within specs, then replace the injector.
Check for voltage at the fuel injector connector. It should have 10 volts or more.
Visually check the connector for damage or broken wires.
Visually check the injector for damage.
If you have access to an injector tester, activate the injector and see if it operates. If the injector operates, then you likely have either an open in the wiring, or a blocked injector. If you do not have access to a tester, swap the injector with another one and see if the code changes. If the code changes, then change the injector.
At the PCM, remove the driver wire from the PCM connector and Ground the wire. (Make sure you have the correct wire. If you're not sure, do not attempt) The injector should activate
Replace the injector
P0601 OBD-II Trouble Code
Technical DescriptionInternal Control Module Memory Check Sum Error
What does that mean?Basically that means that there is an interal fault in the Powertrain Control Module (PCM). There have been many reported PCM failures on Chrysler/Dodge products although it is possible for this to happen on any vehicle. In Dodge/Chrysler products, a P0601 trouble code means that a serial communication failed inside the computer at least 6 times.
SymptomsLikely, no symptoms will be discernible to the driver, other than the illuminated Check Engine Light. Typically the engine runs fine, gauges work, etc.
CausesA code P0601 in most cases means the PCM has gone bad. This is possibly due to a short-circuit inside the PCM. Or, if you disconnect the wires/connector from the PCM while the battery is still connected, that may also cause this code.
Possible SolutionsWith a P0601 OBD-II trouble code, the most common fix is to replace and reprogram the PCM. In a few cases the dealer may be able to reflash the PCM and get it working. But more than likely the PCM will need to be replaced and reprogrammed (we recommend you take it to a dealership for this). The good news is it *may* be covered under your emmissions warranty. So even if you're out of bumper-to-bumper warranty or powertrain warranty, check your warranty guide or dealer to see if this is covered.
Other people have reported that they cleared the code only for it to return again and again. Keep in mind that most shops can replace the PCM but not all can program it.
Mar 27, 2009 at 11:27 AM
RICHARDJMACE
for clarification I replaced my PCM with a rebuilt and programed PCM, could the programing be off causing this error code?
Mar 27, 2009 at 12:23 PM
Do you hear no.2 and 6 injector pulsing? If so check the resistance of the injector-If okay could be the wiring or the computer itself
Mar 28, 2009 at 7:54 AM
