2001 Chrysler Town and Country Low heat
130,000 MILES • 6 CYL • FWD • AUTOMATIC
S7FALCON
  • 7 POSTS
At idle with a warm engine and fan on medium the heat feels warm and a little better in recirc mode. With fan on high the heat drops and, drops more after driving.
The mechanic first changed the thermostat; no change. Then flushed the system to clear a possible air bound problem; at idle the temp read about 135-40. But the heat again dropped off after driving a few miles.
Now he's suggesting a new radiator, that it may be plugged.
Is this the next step, in what seems like a proccess of eliminating what is not the problem? The only thing heating up is me!
Your advice would be greatly appreciated.
John
Dec 22, 2008 at 4:05 AM
ZACKMAN
  • 4,202 POSTS
BASIC HEATER SYSTEM TROUBLE SHOOTING CHART
CONDITION POSSIBLE CAUSE
Insufficient, Erratic, or No Heat Low Coolant Level
..... Incorrect thermostat.
..... Restricted coolant flow through heater core.
..... Heater hoses plugged.
..... Misadjusted control cable.
..... Sticking heater control valve.
..... Vacuum hose leaking.
..... Vacuum hose blocked.
..... Vacuum motors inoperative.
..... Blocked air inlet.
..... Inoperative heater blower motor.
..... Oil residue on heater core fins.
..... Dirt on heater core fins.
***Radiator: If it is not leaking and your vehicle is NOT overheating, then it is fine. I would check for possible clogged heater core, before I touch the radiator.***
Dec 22, 2008 at 1:27 PM
S7FALCON
  • 7 POSTS
The radiator doesn't leak and is not overheating! That's good leave the radiator alone - Is there a way to check the flow thru the heater core without dumping the fluid?
John
Dec 22, 2008 at 2:18 PM
ZACKMAN
  • 4,202 POSTS
No matter what, you will lose some fluid. Instead of removing the hose ends at the heater core, I would remove the hose from the other end from the engine. It is a little harder, but it will be a lot less messier. Get ready with some plastic bags and rubber bands. When you pull a hose out, cover the nipple with the plastic bag and wrap the rubber band around it. Let the fluid in the hose to drain into a bucket or something. Once a hose is removed, attach a T-fitting like this one
https://images.2carpros.com/forum/automotive_pictures/55316_pstafkit_1.jpg
and a garden hose to the other hose, and push all the junk out of the heater core. You may also want to consider refilling with new fluid...
Dec 23, 2008 at 10:51 AM
