2001 Chrysler Town and Country Front a/c does not bloe
2001 CHRYSLER TOWN AND COUNTRY
123,569 MILES • 6 CYL • FWD • AUTOMATIC
TSHASHA
The blower for my front a/c does not work. It went out overnight. the fuse is good and the relay is good. I unpluged the the two wire harness of the blower or at least what I think is the blower behind the glove compartment and checked with a test light to see if there was any voltage. and there was but it was there weather the system was on or off. I don't know where to go from here.
Thanks
Tony
Jun 4, 2010 at 10:55 AM
MERLIN2021
  • 17,250 POSTS
First thing I need to know is do you have temp control or manual A/C? if there is power at the connector to the fan, run a fuse protected wire to the motor from the (+) side of the battery, ground the other one, does the fan run?
Jun 4, 2010 at 12:32 PM
TSHASHA
It does have a temp controlled A/C.
I unplugged the harness and grounded one side and ran battery voltage to the other and nothing happened. There was a noise like it eanted to but nothing.
Jun 6, 2010 at 11:24 AM
TSHASHA
I also need to know what the secret is to getting the blower cover off. I got the front screws out but can not get to the back ones, the insulation is in the way and will not come off without it ripping apart.
Any ideas?
Jun 6, 2010 at 11:31 AM
MERLIN2021
  • 17,250 POSTS
Go to the other side of the firewall and look for screws... If the blower does not blow with a direct battery feed, replace blower motor.
Jun 7, 2010 at 11:57 AM
TSHASHA
It is impossible to get the back screw out without pulling the whole underdash unit out. The back screw points up.
Jun 7, 2010 at 12:06 PM
MERLIN2021
  • 17,250 POSTS
There are two different systems on yours, so I need the production date, early models are hard, late model production ones dont require as much work, the date is on the white door jamb sticker on drivers door, or door jamb. This is a complex and challenging part to replace, not for beginners! Instrument panel, heater plenum, A/c discharging are among the items that need to be removed in the early production vans!
Jun 12, 2010 at 2:13 AM
