2001 Chrysler Town and Country electronic ignition module
89,000 MILES • 6 CYL • FWD • AUTOMATIC
MOMMALOU
put key in and it will not turn. was told by dealer that it was the module but i can't afford the part. seems to do this when it's cold outside. Most days i just jiggle the key in the ignition and it will start. Today, nothing!!! we have tried to do what the repair manual says: remove battery cable and it should release the inside part in the ignition...no go today PLEASE HELP! need car right away.
Nov 11, 2009 at 1:17 PM
BMRFIXIT
  • 19,053 POSTS
If ignition key is not turning then the cylinder need to be replaced
if you would call a lock smith it should be about $100 to $125 for them to replace the cylinder for you
Nov 13, 2009 at 10:06 AM
