2001 Chrysler Town and Country codes po605 &po700
2001 CHRYSLER TOWN AND COUNTRY
WYANT777
Transmission problem
2001 Chrysler Town and Country 6 cyl Two Wheel Drive Automatic
transmission in default mode, only has 2nd gear & reverse has codes p0605 and p0700
Oct 31, 2008 at 5:51 AM
BMRFIXIT
  • 19,053 POSTS
Inspect the following
Engine ground connection s
TCM grounds
TCM battery feed
TCM fused ignition switch output circuit
power feed to transmission control relay
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 7, 2008 at 11:36 AM
