2001 Chrysler Town and Country Check Engine Light/Smog
140,000 MILES • V8 • 2WD • AUTOMATIC
RUSSELLSMOCK
My wifes light came on and stays on. One repair dealership gave codes of P1594 & P0456 and said it needed a smog/smoke pump???? Another dealership said there is not any smog pump on this van. Who is right, we have not done any repairs yet.
Nov 7, 2008 at 9:13 PM
BMRFIXIT
  • 19,053 POSTS
P1594 CHARGING SYSTEM LOW VOLTS check alternator , battery and charging system
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_42.jpg
p0456 leak in the EVAP system possible gas cap (you need a smoke machine to check for leak)its a tool that tech use to check and locate leaks in the evap system (( I think it is a misunderstanding about the smoke pump )) need manual CHECK IT @ https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 7, 2008 at 9:29 PM
