2001 Chrysler Town and Country Check Engine light
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
ORILEYS
The check engine light is on and the cose P0134 comes up. After looking up I found it to be the Oxygen sensor. We are selling the car and want to fix it cheaply. What exactly is the oxygen sensor and can I fix it myself
Mar 15, 2009 at 4:25 AM
DOCFIXIT
  • 18,828 POSTS
Code means no activity in circuit Bank 1 Sensor 1. The side of engine towards radiator sensor before catalytic convertor.Check to see if wiring is intact.
Should be able to replace O2 but not sure that will fix light. If wiring good have code cleared see if it resets.
Mar 16, 2009 at 7:41 AM
SUPERTECT
  • 6 POSTS
I WOULD CHECK OUT THE CATALYTIC CONVERTER , REASON BEING WE DID REPLACE A FEW IN THE DEALER, THEY REPLACE O2 SENSOR AND UP BEING IN THE CAT, WE HAD A FEW WE HAD TO REPLACE, FOOD FOR THOUGHT. EVEN IF IT LOOKS OK, HAD BAD ONE. THANK YOU
Mar 20, 2009 at 2:28 PM
