2001 Chrysler Town and Country ABS Module
2001 CHRYSLER TOWN AND COUNTRY
135,000 MILES • 6 CYL • FWD • AUTOMATIC
JIMW46RETIRED
Break light, ABS light and Trac Off light all come on at the same time. It doesn’t happen all of the time and not always under the same conditions. There is no apparent performance changes.
I took the van to a Chrysler dealer. I was told the ABS module was going bad. The estimate for the repairs calls it a CAB unit. Cost of repairs, $800.
Is there a work around and what is the recommendation? I hate to spend this much on an 8 yr old vehicle.
Sep 17, 2009 at 8:30 AM
BMRFIXIT
  • 19,053 POSTS
Unfortunately if the unit is bad, nothing can be done but replacing it as it is a sealed unit and not serviceable
if you can get the codes ,so we can try and see if its for sure the unit that is bad
Sep 17, 2009 at 10:44 AM
