Our T & C has been intermittently failing to start for the past two years. If we turn the key and hit the steering wheel or underneath the steering column it will start (most of the time). We have occassionally has to leave it sit for a half hour or longer before trying to start. The hitting trick does not always work. I have changed the lock cylinder and the ignition switch in the column without luck. I have switched the relay for the ignition relay and the ASR(?) The problem still exists. Any ideas?
Dec 16, 2009 at 12:32 PM
