2000 Chrysler Town and Country Poor hard/severe/panic braki
2000 CHRYSLER TOWN AND COUNTRY
95,000 MILES • 6 CYL • AWD • AUTOMATIC
WILLARD1
  • 8 POSTS
My daughter's T&C minivan does not seem to brake/slow properly when I really lean, I mean REALLY LEAN, on the brakes.
The way the factory repair manual reads if the proportioning valve failure the rear ABS will be "too" quick to kick in.
In this case I find it impossible to get the ABS to activate at all on dry asphalt and unusually difficult on wet asphalt. And I admit that I cannot really tell if it's the rear ABS that activates first or the front.
Is there any history of the Chrysler minivan (AWD, FIXED) proportioning valves failing at an inordinate level/rate..??
[img:5b1be2273a]http://www.2carpros.com/forum/automotive_pictures/230760_fri3_1.jpg[/img:5b1be2273a]
Aug 21, 2008 at 3:43 AM
  • 110,244 POSTS
Hi:
I haven't seen any TSB regarding the problem. How quickly will the vehicle stop?
Oct 6, 2008 at 2:45 PM
