recently my oil pressure sensor alarm has been coming on intermittently when coming to a stop.the vehicle is well maintained with frequent oil and filther changes.ther are no leaks and the levels are good.If i power brake the vehicle gently raising the RPM to 750-850 the alarm stops.Could this be a clogged sensor or tune up issue or pump issue.I cannot find the recommended rpm at idle setting.
Mar 23, 2009 at 6:30 AM
