My brake lines are leaking?
2000 CHRYSLER TOWN AND COUNTRY
135,000 MILES • 6 CYL • FWD • AUTOMATIC
GBOE
How do you get the brake hoses replaced?
Jan 24, 2009 at 10:25 AM
ZACKMAN
  • 4,202 POSTS
Here are videos to help you make your own line or replace the brake flex hose.
https://youtu.be/sO43p4ZFUiM
and
https://youtu.be/1Prs_coIuCg
The process is the same in most cases.
Jan 25, 2009 at 5:25 PM
DAN SHOAFF
Front lines are leaking, and need to be replaced. How are the lines routed up front?
Mar 15, 2021 at 6:17 AM (Merged)
  • 110,244 POSTS
I have to be honest, in 30 years of working on cars, I've never seen a schematic for brake lines. I don't think they exist. Basically, the steel brake lines run from the master cylinder to the ABS to a proportioning valve and then to the wheels. I don't know if that helps.
