2000 Chrysler Town and Country a/c & heater control pan
2000 CHRYSLER TOWN AND COUNTRY
180,000 MILES • 6 CYL • FWD • AUTOMATIC
RWFULLER
On our minivan the a/c & heater control panel stopped working along with the rear window wiper which is on the same panel. I have already checked all the fuses and none of them are blown. What is the problem?
Jun 25, 2009 at 9:07 AM
KHLOW2008
  • 41,814 POSTS
Hi rwfuller,
Thank you for the donation.
The HVAC contol panel is powered by the Body Control Module which get its power from the # 6 Fuse ( 20 A) located in junction box behind left side of dash.
If fuse is ok, check for power to HVAC control mudule terminal 10 ( Brown/Pink wire) and ground connection at center of dash ( black/Light Green wire)
If both are ok, the problem should be the HVAC control module fault.
Jun 27, 2009 at 2:04 AM
