1999 Chrysler Town and Country The key does not turn around
RULA2000
Electrical problem
1999 Chrysler Town and Country All Wheel Drive Automatic 120000 miles
The key was taken of the switch while car was running (without turning it around). After that, I put the key in the switch and tried to turn it around, it did not work. The key would not turn around at all . Then I turned the steering, so got locked.
Now, I have two problems, the first problem is more important to solve than the second question.
Is there a way that I could make the key turn around inside the switch? Is there a way to unlock the steering.
Jun 7, 2008 at 2:39 PM
MERLIN2021
  • 17,250 POSTS
Try using a small hammer and tapping the key inward...these lock cylinders are known problem areas....200.00 for a new lock, plus labor to install.
Jun 8, 2008 at 12:20 AM
