1999 Chrysler Town and Country Temperature, odometer, and t
1999 CHRYSLER TOWN AND COUNTRY
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
MAZEB
The three above gauges quit functioning the other day. I checked to see if any fuses under the dash, as well as under the hood, were blown. I found none.
I assume the gauges are electronic. All other electrical systems are working just fine. Where should I look to fix the problem?
Apr 19, 2009 at 12:14 AM
CARADIODOC
  • 34,321 POSTS
First, look at the connector pins on the back of the instrument cluster. If they're loose, they can be carefully soldered to the copper circuits. If that doesn't help, it could be the cluster itself which is now a computer module, or it could be the Body computer.
By computerizing everything, the system has become very unreliable and expensive to repair. That's why I still drive a 1988 Grand Caravan!
caradiodoc
Apr 19, 2009 at 3:28 AM
