After a 10Min ride I stopped at bank. 15mins later when I turned key to start there is a hissing noise and no cranking. Ligts and all other off. Batt. OK. Tried couple of times. It appeared as if the starter is not working. After half hour, I tried the ignition, Boy Engine cranked and started OK. This morning outside temp was minus 5 degrees F. Car started fine.
SPONSORED LINKS
Friday, January 16th, 2009 AT 12:55 PM
