Chrysler Town and Country models not starting sometimes?
SAPEACHEY
  • 1999 CHRYSLER TOWN AND COUNTRY
  • 6 CYL
  • 270,000 MILES
Just wondering if anyone has found what the problem is for the chrysler town and country models not starting sometimes. Battery fine, turns over about 7 times then after that nothing. Just happens randomly sometimes will start after min, hours, but now it is days before it starts. It has been broughten to dealership 5 time and they has no idea, as it will start after being towed there. Have been told that may be factory security system of some time of cam sensor?
Friday, July 4th, 2008 AT 10:29 AM
TLHILTON
I also have a 1999 T&C I have had the same problem and it is getting more common and taking longer to start.I had a mechanic her today who tells me it is 1 of 2 things.1. Crank sensor which runs around $60.
2. ECu wiring harness which can only be ordered thru the dealership and runjs about $700. I hope this helps you out I'm going to start by trying the crank sensor I'll let you know how it turns out.
Monday, August 31st, 2020 AT 1:23 PM
Related Engine Not Cranking Over Content
Car Not Cranking? Try This | EASY
VIDEO
