Hi there,
This may be a belt that has stretched and the adjuster can not keep adequate tension up to it, or some minor misalignment in a pulley, allowing it to walk off when wet and a bit slippery, don't use any belt grip in a can, this will only make matters worse, check for a worn belt and check for any pulley misalignment.
Mark (mhpautos)
Dec 15, 2007 at 7:56 AM
