1999 Chrysler Town and Country Powertrain Control Module
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANGEL PINEIRO
I was searching the web for the Powertrain Control Module and it came up with NIEHOFF Ignition Computer. Are these the same parts with a different name? Does this vehicle have a Powertrain Control Module? I took the car to the mechanic because the car will not turn on unless you jump start it by connecting a cable directly to the starter and the other to the battery. The mechanic stated the Powertrain Control Module is bad. How can I confirm this is an accurate diagnosis?
Jun 14, 2008 at 1:30 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:432af995a6="Angel Pineiro"]Engine Performance problem
1999 Chrysler Town and Country 6 cyl Two Wheel Drive Automatic 160000 miles
I was searching the web for the Powertrain Control Module and it came up with NIEHOFF Ignition Computer. Are these the same parts with a different name? Does this vehicle have a Powertrain Control Module? I took the car to the mechanic because the car will not turn on unless you jump start it by connecting a cable directly to the starter and the other to the battery. The mechanic stated the Powertrain Control Module is bad. How can I confirm this is an accurate diagnosis?[/quote:432af995a6]
I am going to take a wild guess and say that everything on the vehicle works fine once started right?
If so I would look at the Ignition Switch or the Ignition Fuse or Relay, Not the PCM.
Jun 15, 2008 at 3:18 PM
