I have an intermitant problem with theoil pressure indicator light coming on. Occassionally at idle the oil pressure light comes on. This does not happen every time. Also when the pressure was checked by a gauge it indicated from 50 lbs to 18 lbs pressure. What do you suggest?
Nov 22, 2008 at 11:59 PM
