1999 Chrysler Town and Country gears
228,000 MILES • 6 CYL • FWD • AUTOMATIC
SJ70YEARS
I was told that the "D" (Over Driver) on gear shift should be used only on highway driving and "3" should be in town where you expect to start and stop. Is this true?
Also, when going down the highway it seems to jerk a little once in a while and was told it was a Tork Convertor?
Could these be right?
Thanks so much
Aug 1, 2009 at 2:41 PM
BMRFIXIT
  • 19,053 POSTS
not true at all you can drive on OD any time and should with no issue and problem
check tranny fluids and do a code check
Aug 2, 2009 at 1:53 PM
